Preparing mitre joints in oak
16 Dec 2006
Avon
I'm seeking advice from seasoned woodwurmers here. I'm planning to fit solid oak treads ( 170 x 20mm ) onto a Bath stone step between two rooms - which was once the base of a 135º bay window. I'm planning to join the mitre-joints using a Kreg 'pocket hole' jig and s/t screws. Naturally, I want to cut the mitre-joints 'exactly', and am uncertain how best to mark up and cut them to avoid splintering and 'breakout'.
Now, I have a sliding mitre saw with a fresh general purpose 210 x 2.8mm blade. I also have a couple of routers, a new small router table, and a box of new Chinese t/c cutters.
What does the team suggest 'for best' as to marking up, course cutting, then fine exact cutting of the mitres - to avoid damaged wood? .....and any other sound advice.
Depending on the quality and accuracy of your saw that should do the job, if you cut with the board face up the splinters will be on the base/back.
Alternatively you can cut the boards with a few mm to spare, clamp a straight edve to your cut line and use a flush bit in the router to trim the board. Working from the front edge to the rear this will give a better finish than the saw provided your cutters are decent and you are able to use the router without wobble.
As for marking out you can lay one piece of board over the other and mark where they cross at the back and front, then join these two points to get your cut line but a bit of trial and error will be needed.
Jason
