do you need a pressure reducing valve if your hot water is pumped the pressure reducing valve is on the cold water and since the pump has been fitted it seems to block up ?
the manual doesnt say anything about it seems odd to me that since i fitted it on the hot water the cold water pressure reducing valve on the main cold coming in has now stoppped working :S
i know they shouldnt but it is the problem because if i remove it the problem is fixed im just wondering would it be a problem if i didnt put it back in.
