Last winter our new house suffered damage to all the gutters. Roof material is sheet aluminium, about 45 degrees pitch. The guttering is galvanised "lindab" system. After the first two snow episodes we thought the winter was over so I borrowed a neighbours ladders and dismantled the gutters, removed the metal clips(some were ripped off clean) and bent them back to their normal shape and refitted the whole system fine. Then it snowed again and the damage is back....
Given I had to use a fair amount of strength to bend the clips with one end down a scaffold tube would increasing the amount of clips help prevent this by better spreading out what is a considerable load? Or prior to this would I need to thoroughly screw the fascia to the ends of the pitched joists as this would now be a weak point?
I'm tempted to just remove the gutters(leaving the clips) at the start of winter because the overhang of the eaves is pretty substantial, the ground below is freely draining and the house is 300mm above GL cos it's on stilts!!!(which is allowing supercooled air to be drawn through the floor freezing the pipes but that's another thread!)
Or can anyone advise any other method or solution? I've tried dislodging the snow but on a ladder it's friggin dangerous and once ice has formed in the gutters it's a lost cause anyway...
