Price guide?
8 May 2009
Bedfordshire
Hi, I’m looking for advice on the most suitable system i should install in my extended house which currently has a combi boiler.
We require a new boiler and 8 news rads to be installed into the extension.
Is it best to fit just another, larger combi or go for a megaflow type system? It is worth the extra ££?? or is there another option? There will be 5 rads left in the original house to integrate with.
total: 13 rads, 1 new boiler and possible megaflow type system
what are your thoughts?
There are few basic questions such as flow rate and pressure that need to be answered and if those can be satisfied then an unvented system where you can still utilise your combination boiler would be a good choice
How many bathrooms do you have and how many people living there ,a local heating company should be your first port of call ,someone pehaps recommended by friends or collegues
In virtually every standard size house you can go for either a combi or a megaflo as long as the gas and water supply are adequate.
The only one who can tell you what the best option is, is the chap that will install it and has checked the technical side as well as your wants and needs.
We don't do price estimates here as the forum is for technical stuff only.
