Problem radiators
Hi, both the hot water and heating knobs are both set at number 5, which is where they have always been.
You could try turning the heating knob to a higher number to see if it makes any difference.
If you feel the two pipes connected to a radiator, one should be hot (flow) and the other cooler (return), but not cold. Use the two pipes connected to the boiler on the right as a guide. Any rads where the pipes feel significantly different from the boiler need further investigation.
