Remove the Black plasic cover from the front of the burner 4mm Allen key
Remove the Photo Cell, and clean the Glass tip so that it can see the flame, refit and try again, if this does not work photocell , or control box may be faulty, but make sure the flame is good as an unstable flame will cause problems
