Problem with socket
27 Sep 2011
West Midlands
I am just starting to decorate a bedroom, in the room is a double socket containing 2 cables the red obviously live are twisted together and put into the live part of the switch, the neutral black are twisted together and put into the neutral part of the switch, but I found out that one of the black wires is live ( i got a shock from it.) it disappears into the wall I have no idea where it goes next or where it comes from I'm assuming that some where else it must be connected to a live wire? How do I find where it goes or comes from and how the hell has it worked ok before?
I need some HELP :oops:
1) WHY ARE YOU TOUCHING WIRES AT THE BACK OF SOCKETS (OR SWITCHES) WHEN THE POWER IS STILL ON?
2) Is this a socket or a switch? You first called it a socket, but then twice you called it a switch.
3) Do you have 2 twin and earth cables? You talk about one of the black wires disappearing into the wall - what about the other one and the two reds? Photos would be useful.
BUT FGS TURN THE POWER OFF!
BAS it absolutely right.
Four things you should know
Black is a colour, it does not necessarily indicate the function of the copper conductor underneath the black skin
Neutral is defied as a LIVE conductor
(As you now know) do not assume anything about any electrical installation
Always, always carry out safe isolation procedures. These are detailed in the STICKY at the top of this forum.
My signature tells you why its a great idea.
Thank you for your reply
1/ I realise that was a rather stupid thing to do and will turn off the power in future.
2/It is a switched socket 2 gang
3/Yes there are two twin and earth cables both of then go down through the bottom of the back box in the wall
Sorry I haven't made my self clear
2 reds both live into 1 connection (L) rear of plug
2 blacks 1 live 1 not into 1 connection (N) in back of plug
IS IT NORMAL AND IS IT SAFE?
2 blacks, one live and one not?
how do you know ones live and the other isnt?
If it's worked before and still works now, the perhaps the best approach is to leave it alone before you kill yourself?
Is there actually a problem with the socket? If so, have you considered paying an electrician to sort it, got to be cheaper/easier than a funeral?
Socket.
Socket.
And if they were connected together they must both be at the same potential, or there'd be fuses blowing/MCBs tripping...
What else were you touching apart from that black wire?
Thank
yes it is a screwdriver type tester
and i just caught one of the earth wires and in tripped out in the distributiion board
I think ill just put it all back as it was
Thank
that sounds like the best option, i cant see any problem with what you are saying.
(without seeing a picture) it sounds fine.
If it was the RCD that tripped when the black wire touched earth then this is normal behaviour.
This can happen even if the MCB for the circuit is switched off.
The reasons are described here http://www.diynot.com/wiki/electrics:rcds
Re your screwdriver tester.
As hightlighted in another thread. You should go to your local police station with the screwdriver, look for the amnesty bin and drop it in(it will be by the custody sergeant's desk).
:D
