I've had a GET wireless lighting system fitted which for several weeks worked fine.
After about 2 months, one of the wall receivers malfunctioned so the lights were permanently on and could not be switch off. The receiver was replaced and for around 6 weeks everything was fine. Then the same thing happened again.
Also, another receiver has started to malfunction. If I turn the lights to full, the lights then can not turn off. If I only turn them on part way, everything is OK. Once the lights have locked on, the only way to turn them off is to switch the circuit off at the junction box and leave it for 10 minutes. Then everything is back to working normally.
I'm sure that there is nothing wrong with the installation. It's fairly simple and it all worked fine for several weeks. And the other 2 receivers (I have 4) have no problems.
Any suggestion on how I can start to track down this rather strange problem - or is the Get Smart lighting system just a bit unreliable.
Richard
Richard
