Hi, I have had some good help from people on other boards here before, so wondering if someone can help me with a couple of lighting questions!
We moved into a new house a while back, which has halogen spots all over the place, but we don't have much information on the type of bulbs and fittings so I am having some trouble with them.
The first problem is that 2 of the ones in the hall have stopped working, I assumed it just meant the bulbs had gone but am having problems getting them working again.
The bulbs seem to be standard MR16 halogen spots (12v, 50w, 2 straight pins as opposed to the ones with the lumps on the end). So I got some new bulbs which seem exactly the same. But when I put these into the fittings, they don't work. Before I tried replacing them, one of the lights was completely dead (didn't switch on at all), and the other would switch on briefly but then fade out after a short time. But with the new bulbs, I can't get either of them to switch on at all. (PS I tried with different bulbs from the same packet, so it's not just a case of one duff bulb). Worse, now I have put the old bulbs back in, the one which would come on briefly before is also completely dead...
Is it possible I have the wrong type of bulbs, or what else could be stopping it working? I wondered about a bad connection or similar, but wiggling them a bit didn't seem to make any difference.
The other problem I've had is with the spots in the bathroom. They are in a different type of fitting, with the bulbs completely enclosed in a casing (presumably a bathroom safety thing?). But I can't figure out how to get them out to replace the bulbs that have gone. I can get them slightly loose but it seems like they are held in somehow and I can't see enough to figure out how (unless you are meant to get at them from above?? but very impractical if so!). I am a bit scared of damaging something if I try to force them too hard - anyone know the proper way to get these out?
Thank you!
Thank you!
