Problems with room thermostat
11 Oct 2003
I have recently installed a room thermostat.(Tower RS).When activated the boiler only comes on for about a minute and then shuts off,therefore the room does not warm to the set temperature.It would appear to me that the thermostat warms up or senses a greater heat once activated than it actually is?I am not sure if this is a problem with the wiring or the thermostat itself?
you may have the thermostat conneted the wrong way round.
what terminals does it have?
if it has No C and Nc and you are using Nc and C try C and No
I suggest this should go in the plumbing section! Was there a stat there before and did it work?
What boiler?
Some boilers are expensively damaged by connecting a room stat wrongly!
What boiler?
There was no thermostat there before.I have just recently fitted it for heating control
