The simple question is: Where is the best place to get some good advice on dampness looking at the wider view of house construction/modification and surrounding ground conditions?
The longer question is: The house is detached, 4 bedroom, built c1890, all features ripped out in 1970s (including fireplaces, chimney breasts etc), concreted around house, solid concrete floors on ground floor (since '60s apparently), c1' thick brick walls, now clad with good quality hard smooth finish, c2'deep brickwork below ground, no foundations. I have dug a hole behind the house and the "water level" is only about 6" below ground level. As the concrete floor level is the same as the outside concrete level it doesn't seem surprising that there is a damp problem. i am only surprised that it is not as bad as it could be.
My amateur guess is that:
- All the concrete around the house should be removed to about 2' away
- Drainage/soakaway put around the house
- Leave cladding as-is (even though I would like to remove) as the bricks could be damaged underneath and it could be costly to remove
- Don't do the damp proof as it is as simple as draining water and letting moisture out.
Just need a professional to advise on the above in situ before I get quotes. I am wary because this is a minefield of snake oil salesman peddling damp solutions. How do I find a trusted adviser (in Kent)
