Hi again, I've been doing some reading up thanks to these excellent forums etc and hope I've come up with a safe wiring solution for the Kitchen (first floor flat)
Can I ask for suitably qualified eyes to once over the pdf wiring plan to see if there's anything wrong with it please?
http://homepages.nildram.co.uk/~mackie/KitchenElectricsDesign.pdf
<edit> Sorry, its been saved as portrait by default. R-Click to select rotate. Also I want to mention that atm the CU has a 32A MCB on the cooker radial circuit. The oven I intend to use is a 16Amp siemens beastie and will be hard wired into the Cooker outlet plate, hence I have shown a 16A MCB in the CU.
First question, do I have to use a dedicated Cooker Control Unit (red switch variety) or is the 20Amp switched FCU sufficient?
