protect veneer wood from moisture
16 May 2011
I have a bathroom cabinet under the basin which gets often wet from water spilled from the tap above. The material looks like veneer finish on MDF. I know that there are oils for real wood but I am not aware of something for veneer. Is there any treatment, like a cream or spray, to protect the veneer cupboard from the bathroom moisture?
what your likely to have is a paper printed design covered in plastic same as cheap laminate flooring an even worktops
unless it say wood veneer or solid wood its plastic/resin
they will use words like
"country oak style "
"antique pine effect"
have you got a llink to your cabinet :?: :?:
Sorry, I do not have a web link. It must be a kind of self-adhesive print not real wood veneer. It looks that it deteriorates mostly in the seams so I thought if I there is any a product to polish the cabinet and protect from moisture.
