just moved house and there is an old style 4 way consumer unit with fuses in the garage, which is connected to the main consumer unit via a 10mm cable. three circuits run off the 4 way - 1 lighting for the garage, 1 sockets for the garage, and 1 sockets for the shed.
What is the best way to improve this - just so I know what to ask when I find an electrician as I like to at least appear that I know roughly what I'm talking about!
I'm guessing I want to replace the consumer unit with a split load rcd? I have a couple of rooms attached to the garage (which is attached to the house) so I want the option of maybe adding another socket ring main or two in the future so was thinking of maybe an 8 way RCD.
Is it OK to run a seperate RCD off a main FCU with a 10mm cable ?
What type of breaker is required for an outside circuit? the cable to the shed is 4mm armoured cable, and supplies two sockets with a light spurred through a fuse.
Thx in advance for any advice
