PRV Leaking on Megaflo
Tank is overheating ,... causing the temperature prv to open ,...
is the mega flow being heated by a element or primary coil ?
the prv will open at 95c
Are you using both electric element and primary heating coil to heat the megaflow ? :roll:
Water discharges Intermittently, the expansion volume is reduced within the unit, proceed as instruction above.
Continually, cold water combination valve faulty/not working, check pressure and reduce if over 3.5 bar.
Only other fault will discharge very hot water, and be atributed to thermal control failure.
Brumylad.
Calorifiers do collaspe and you must drain the primary water before you can drain the secondary
awaites brummy lads reply !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
let it slip mate...there is only 2 questions in that post :)
internal expnasion ski :oops: :oops: :oops:
2 direct questions + 1 = 3
another idiot who has no idea :roll:
ollski said:
pro said:
Bubble thing stops prv from leaking ,?
Check the ovious -hot water temperature to hot ?
Scale inside the unit ? (is there a good water flow)?
prv could be doing what it,s desighed to do * release preasure ffs
call a corgi man * £75 pr half hr
or bg £ 350 pr yr no guarantee of time arrival
Ummm yes bubble thing = internal expansion......what are the prices for??
Jesus 26 posts, not a single one helpful and lots of new friends made along the way.....ideal screwfix forum material :idea:
excuss me, I told the guy what was wrong and how to cure it.
DIA Another corgi wanna be *
ask your wife for the registration fee DO IT ALL *
Haven't got one moron she died on Tuesday, so get back to your kiddies
DO IT ALL ( you did,t fix her boiler on tuesday did you ?)
MOD
see 4
then behave
