    Dismiss Notice
pull up bar
Discussion in 'Windows and Doors' started by saleemarshad, 10 May 2010.
  1. saleemarshad
    saleemarshad
    26 Apr 2010
    8
    Thanks Received:
    London
    Country:
    hello
    i bought a chin up bar that i could fit on a door way frame how ever the frame is far too small.
    i was looking for advice for fitting it on the passageway on plasterboard.
    will it hold? im abt 80 kgs,
    your help is appreciated.
    thanks
    saleem
  2. Ker-plunk
    Ker-plunk
    21 Nov 2008
    5,711
    Thanks Received:
    811
    uk
    Country:
    No the p/b will not hold the bar!.
    • Thanks Thanks x 1
  3. saleemarshad
    saleemarshad
    26 Apr 2010
    8
    Thanks Received:
    London
    Country:
  4. big-all
    big-all
    12 Jul 2004
    17,555
    Thanks Received:
    1,301
    Surrey
    Country:
    4x1" par timber approximatly 1m long to fit over 3 studs assuming they are at 400 centres with a bit extra incase the other wall studs are slightly different position
    lay the timber on the floor find the 3 studs each side move the timber untill the centres are opposit and on or equal distance from the centre stud
    secure to the studs with no 10x3"[ 5mmx 80mm] 2 on each off the three studs at the required height
    the above assumes normal timber studs of around 4x2" at 400mm centres
Loading...
Share This Page
