Pump fallen to bits
17 Jan 2006
Derbyshire
I have just been to go in the shower and found no water pressure so i checked the taps and cold is fine but hot is only a trickle. I open the boiler up (Sime Friendly combi) and find that the bottom of the pump has come away from the body. The heating still seems to be working but the water is not. There are no leaks luckily from the pump itself. Can the body just be replaced on the pump instead of having to remove the pipework? Im guessing a grundfos would be ok in its place. Are these types of pump expensive to replace?
Heres a pic of it.
you could tape the box back onto the pump, if its working the wiring is obviously ok. no need to replace.(might be worth turning power off while you do it)
Looks like a Myson or now called circulating pumps, pump.
Whether a standard pump head would fit, I do not know. Usually best to stick to original when replacing.
There is no flow to the hot water taps though. Its strange how it has just dropped off. I would guess that it should still work even though its seperated, is there something else stopping the hot water coming then??
Does this pump the water round the rads aswell as the hot water to the taps?? I will definatly get it replaced, its just now not so much of a worry of getting it replaced because we have no hot water. Wont need an emergancy call out added on top of the bits.
Your pump does the same for both CH and for DHW.
Tape it up as told!
If the boiler is not responding to a demand for DHW then its a diverter valve fault.
Tony
