Push fit connector - help!
14 Apr 2004
I've bought a pack of push fit reducing connectors like the one below to fit on the pipes in my fridge/freezer
http://www.theworkshopwarehouse.co....couplings-reducing-straights-metric-2634.html
I shoved each end of the pipes into each end of the connector and turn on the water and its leaking out one side. But I can't get the damn thing off.
A) why could it be leaking? The cables are already clean cut.
B) if I need to get it off how do I without cutting the cable?
C) what am i doing wrong?
Cheers! :?
K
I'm confused but have you tried compressing the ends of the fitting to release the pipe, or cable or whatever it is you are connecting on your freezer????? :?
View media item 45922That ring should push in towards the body of the fitting, allowing you to dismount the fitting from the pipe.
Have you used inserts? From the John Guest website:
Plastic Tube - Polyethylene, nylon and polyurethane conforming to the tolerances shown below. For soft tubing or thin wall tube we recommend the use of tube inserts.
Inserts, stiffeners, liners:
