Pyronix “Wireless Ch To”
17 Jul 2018
Not a regular thread from doing a search but bizzarely when I was in a panel log for a totally unrelated issue the first thing that popped up today (this morning) was “Wireless Ch To” on pressing C showed “Channel 1 - RF Switch”
Never saw this before so stepped back the logs and about a week ago the same except Channel 2 was referenced.
Clearly some wireless interference? Do I just leave it to do it’s thing? Will it cause any wider issues?
It’s automatically switched frequency due to an outside source causing interference....
Could that be another panel. There are another 7 houses... 3 my side and 4 opposite and I’ve installed systems in them all
Yes, ask neighbours if same fault on their control panels.
Street lights on wireless timers, garage door operator's, taxis, any item that uses a radio frequency could be causing an issue.
Pyronix control panel usually switch frequency to stop this from happening.
Then yes it could easily be another panel. Could be the 7 panels are all competing against each other for a clear channels.
and then you ask for advice on a DIY forum when one of the harsh realities of Licence Exempt wireless communication rears it's head
So any way of fixing the jumping if it’s the panels competing against one another?
One option is to have the systems allocated time slots when they have exclusive use of the wireless channel. This requires linking them to an allocator
Why ? ..it’s designed to do this to stop issues ....
Channel changing works reasonably well when there are more channels than there are competing systems. I cannot recall how many channels are available for intruder alarms ( assuming it is 868,xx MHz ) but if it is less than 8 and there are 8 intruder alarms affecting each other then there will be a lot of channel changing.
