Hi there, hate to be new and jump in with questions but am banging my head against the wall with ringing ears.
I have physically installed the main panel and a euro46 wired keypad. This is connected to the io board with no resistors as that seemed how the install manual has it. There are no other wired devices.
I had powered up the main board once before, now when I turn it on I am told comms lost (there is no coins board at this time). The unit then says please wait and boots to normal.
If left it alarms and I see no way to disarm. There is no text on screen just the internal sounder. If I hold d and input either master or engineer codes (1 or 2) as given in the manual the screen goes blank and does nothing. Once it went blank with a 1 down the bottom right.
I was expecting to set the date and start learning inputs but that seems not the case.
The keypad seems to work fine and mimics the main panel.
The manual and YouTube videos seem so simple so I know I am missing something simple.
I will unwire the keypad and see what happens but I do need that as part of the system as the main panel is deliberately hard to access.
Thanks in advanced for any assistance.
Keypad is unwired and makes no difference.
