Pyronix Enforcer - issues
3 Jul 2016
Hi, Sorry if this in the wrong place.
I have an issue with my Alarm system that I am in the process of setting up. I have set up my older veritas a few years back. but these newer ones im not a fan of.
It is a Pyronix Enforcer Homecontrol+, with all the wireless sensors etc.
On 2 of the sensors, (1 PIR, and 1 Window Shock Sensor) every time I go to set the alarm I get an 'input tamper error' and the system will not allow me to set the system.
I have been and checked the sensor, and both appear to have been fit correctly but I cannot figure out the cause of the error.
Problem 2. I have set up 3 zones (A, B and C). for zone D I did not require it therefore it wasn't used and hasn't been programmed in to any of the sensors. So somehow (possibly my error) Zone D has been set and turned on and I cannot access the engineer menu to finish off the set up.
Is there any fixes for the above issues.
Thanks in advance
Enter manager code to turn off D setting 2222 default or try 1234 , have you been messing with the code settings for manager or user 1 ?
