Hi
I just moved into a new place with an existing Pyronix Enforcer with a deltabell sounder from 2013. It hadn't been used for a while so I changed the batteries in the sounder and all the door sensors and PIRs but I am still getting a low battery error on the control panel which lists all the devices I thought I'd fixed.
When I try to arm the system I need to select to override the warnings and then it counts down but when it gets to zero nothing seems to happen.
Is there a way to reset it so it recognises that the batteries are all fine and would that then enable it to arm the alarm as normal?
I think the code I have is the user code and no way to get engineer code.
Any help gratefully appreciated.
thanks
thanks
