Pyronix Enforcer - Tamper Error /Admin password reset?
Are the 2 wire links fitted on the terminals at the end ?
They are
I also just checked the signal in engineer mode and it seems both the shock and the MC elements are showing as zero signal, which tells me for some reason this sensor is not communicating with the panel.
So I am thinking I should just delete it from the wireless device list, and both shock and MC back via the learn process. If it fails, then it's a new MC1 needed.
Seems sensible, or anything I haven't thought about?
Yes that sounds good. Did u take the device to the panel location and check the signal ? You will also need to recalibrate the shock sensor if you can get it learned back on. Arrow on inertia barrel should be pointing upwards and 1 click negative before u do this.
I did and it didn't recognise it i.e 0 signal, seems like it's lost its registration to the panel or is just simply faulty. Thanks for the tip on how to install
Strange how it only happened when u changed the battery. Have u walk tested the other devices to make sure they are communicating OK?
The other devices are showing a signal, but I could walk test it as a double check.
Agree it's weird, wonder if I clipped the learn button and it reset it. Seems unlikely though
