Pyronix MEQ Blue Quad PIR Detector with Risco LightSYS2
30 Sep 2010
Yorkshire
Hi all,
Is it possible to use the Pyronix MEQ Blue Quad PIR Detector with a LightSYS2 alarm.
The LightSYS supports wired sensors, but is lacking any connections for tamper. So being an armature at this it looks to me like I should use Double End of Line resistors so the LightSYS can see the change in tamper or Alarm condition?
(currently all the sensors are wireless, however the house was pre-wired and Id like to start using these. The Pyronix seem to be small and have a high Wife acceptance factor)
Many thanks for your help..
lol HWAF
use resistors on all detectors, I believe that all zones have to use the same resistor values and you cant mix and match.
Thanks...
So there is nothing limiting me just to RISCO sensors?
Believe the value is 2.2k @12v
just wire in the resistors to the sensors for the values you have assigned in the programming.
so DEOL ID 13 2.2K eol and 4k7 across the alarm pair. or the default value DEOL ID 1 is 2.2K, 2.2K
the panel may have a pack of 16 2.2K resistors
There are no 2.2k resistors, these are Red Red Red?
So I will also need some 4.7k resistors..?
The manual does just show 2.2k across alarm and tamper.. (Page 28)
But as you said it also shows 4.7k for ID 13
