Question For The DNO Guys
11 Jun 2013
Yorkshire
About 7 years ago we had a brand new three phase supply to our coffee shop and until now we have never seen it as the cables etc were covered by stone (stone covered duct)
Im just a bit puzzled by what we have...
There is a cable coming from the road and it says on the sheath (3 x 70mm) then that goes in to a resin joint (along with a 25mm earth cable from a spike) from there a 16mm cable comes out of it in to our shop.
Few questions...
1. I take it we have a TT supply?
2. If the cable says 3 x 70mm where does our neutral come from?
3. Why has it been done this way?
4. why does the earth go from a spike in to the joint then join to the outgoing cable?
Sorry for all the questions, just curious.
Thanks!
Because there is an earth rod it does not mean it's TT the PME (TN-C-S) the ME means "multiple earths" and the DNO is allowed to use same conductor for earth and neutral. I would guess earth and neutral is using outer case.
The DNO rules are different to what we are allowed to do they seem to be a law onto themselves.
More or less what eric said.
Any cable we use is labelled with the core size so that will be a 3 core & concentric neutral/earth.
Because it is terminated and a service taken from it we are obliged to fit a nominal earth rod to the N/E, which becomes part of the "multiple earth"
the rod will be connected directly to the N/E not via the service cable.
Thanks for your replies, is there any particular reason there is a 70mm cable coming down the field and then jointed to a 16/25mm?
I'm no expert on DNO practices, but an educated guess would be either....
70mm is required due to the run length to keep voltage drop and/or fault loop impedance within spec.
OR
To allow for future expansion
Or a bit of both
Or it's cheaper to just buy one size for cables, joints etc
We only have 3 sizes of mains cable, two sizes of service cable (house and street furniture).
I wish I had a pound for every time I have heard that off consumers, sorry customers ;-)
