A
Alltheones
Ok so the set up I have at the moment a 32mm basin pipe it T ( sweeping but it’s upside down) connected into a 40mm from the shower waste which then goes into a push fit connection on a T soil under the toilet then soil goes around 1m horizontal too vertical soil one way and capped off the other, all this has fall but I’m worried about the sink emptying the shower trap.
first question is that a possible outcome with this set up.
My easy option to fix this is cut the 32mm off just after the elbow which goes too the T and fit a end cap then extend the 32mm into the end cap off the soil with either a pre made cap with waste outlet or drill the cap out and fit a waste push fit.
my question for this is, will the capped off T with a short return cause any issues to the draining of the shower.
And is the idea with the 32mm into the end cap right.
cheers.
cheers.
