I am just in the final stages of an extension on my house and the meter box is soon to be moved. The problem is that the new position of the meter box is about 12 metres from my consumer unit (as the cable goes)and I really dont want to be moving the consumer unit.
What is my workaround if one without having to move the consumer unit? Would I fit a 100A switch between the meter and the consumer unit? ie the switch is within 3 metres of the meter then I take a feed from the switch to the consumer unit? If so can this switch be fitted inside the meter box? i would then run the 12metre run from that to the CU.
I also assume its acceptable to run the cables behind the dot and dab plasterboard.
Also one other question is what are the regulations for downlighters. I have bought fire compliant ones, but what would the final inspection on the house to pass it off say about the gaps I would need to leave in the loft insulation for the downlighters? These would of course cause heat loss where no insulation is.
Please keep answers as clear english as poss )) I will be having pros into do the work, but I want to know whats what myself before I do that.
Many thanks in advance for your help.
Neil
Neil
