Rain on walls
22 Dec 2024
Any thoughts on what I can do to stop the rain dripping down onto the walls as shown in the attached photo? Seems to be coming through the concrete joint at the base of the tile joint.
Hi there!
It looks like you might be dealing with a leak around the base of your tiles. This could be caused by a few things, like cracked sealant or missing flashing.
To help you understand potential causes and identify the problem, I recommend checking out this helpful resource from Acute Roofing: Roof Maintenance Checklist.
While this checklist might give you some initial insights, it's always best to have a qualified roofer inspect the leak properly.
Hope this helps!
Best regards
Its not unusual for the drip to fail at the mortar joint, as very few builders will shape the mortar to continue the drip.
