Rain water under lead flashing leading to leak below
22 Nov 2026
Hi guys,
I bought a semi-detached dorma bungalow during the summer and now it’s winter, I’ve noticed a leak through the soffit boards above my back door when it rains. After a lot of investigation, I think I’ve found the problem! I pulled back the lead flashing on the side of the dorma and found that it was wet underneath and water was dripping off the bottom tile inside. I assume it’s collecting on top of the soffit board beneath and seeping through on the wall. Question is instead of getting a roofer out, what’s the best approach for me to tackle this myself. Any advice? Thanks
Not a roofer but I would think you need risers on top of each tile then fold the lead flashing down over them. If I am seeing your pics correctly.
If you are getting water into the soffits I would also check the felt is still hanging over into the gutters and hasn't torn off as old felt does.
Hi guys,
The abutment flashing is completely wrong and doing absolutely nothing.
It needs some code four 300mm (you might get away with 230mm depending on the tile profile) laying on top of the tiles and step chased into the masonry.
It was never right, but the felt underlay has probably been keeping it dry until it degraded.
From your image, I think the lead needed to be about an inch wider.
There's a couple of ways of doing it, but what you have, ain't one of them.
COde 4 lead doing this sort of thing, for example:
@catlad is correct.
The lead needs to be wider to go over that tile profile so water can't travel under it.
With this kind of tiles you need to account for the profile and make sure water running down the lead falls into the "valley" profile.
As a temporary measure, you could slide a length of lead under the existing and dress it properly, rising upwards against the wall and then on tile side, down into the "valley" profile.
I would also stick it to the other lead with leadmate to survive the winter.
This is only a temporary fix and will need to be done properly.
Well you could use a (secret) soaker(s) as well. Ideally one per course of tiles. Going on top is more common with thick tiles though, as johnny said into the valley part of the tile profile. Underneath is more common for slates.
If you on;ly go under, particularly with thick tiles, debris collects between the cut edge of the tile and the abutment (vertical bit) and sends all the water sideways under the tiles.
Catlad I'm not sure what you meant by using lead an inch wider - were you being sarcastic?!:giggle:
NO! As Johnny has just mentioned, when using profiled tiles, the lead needs to be wide enough to make it into one of the troughs of the tiles, so it continues down the roof in the troughs, and not going side ways under the lead flashing. To my eyes! Which are not as sharp as they once were, that lead looks to narrow.
I was looking at the lead sticking up I'm the air, obviously bonkers and pretty useless. Like that, an inch wider would make b all difference! Hence my thinking maybe there was sarcasm there.
Yes soaker detail would depend on overlap + , etc, modern dry soakers don't sag the same as lead.
I'm not a roofer but I've repaired a number when I had renters. Mate WAS a roofer telling me what to do. I did lead bashing in c&g, quite enjoyed it.
Rain blowing under topside lead , etc, was an annoyingly common problem on old materials on my places even where the book method was used, so belt & braces applied. Not Aluminium.
So what are you saying is wrong with the approach in the pic I found - granted those aren't interlocking tiles.?
Assuming he doesn't want to clad the whole dormer.....
