ravenheat condensing combi 85t
4 Feb 2011
boiler runs on its own then overheats and starts ketling then cuts out this hapens when on hot water only runs fine on htg no probs need some pointers boiler had leaks prior to this they where fixed then this started
the only honest pointer i can give u is the scrap heap...failing that get it on a bg service contract cos this heap will carry on breaking down year after year :roll:
It would appear there is a restriction between the plate and main heat exchangers.Maybe the divertor is stuck or the plate heat exchanger is blocked.
Most likely a faulty DHW ntc sensor (?) boiler will still provide hot water but will not modulate . noisey , ketteling , eventuall high limit lock out probably , ch is under control of another sensor !
Ravenheat csi = condensing system innovation , the worlds only (?) A rated atmospheric condensing boiler ???
Think it was one of these that I had to scrap at 3 years old fitted by warmfront, 10 leaks all Ravenheats, crossed thread on diverer from new and blown pcb, bag of ****e.
