I am sorry if you think I was condescending or my advice was pointless.
I was advising you read up on what the test involves and how to interpret the results. As an experienced electrician, this is advice I would give anybody starting out. The instruction manual will tell you how to use the tester, but not what any readings indicate.
I would point out that the Insulation Resistance test should be carried out before you energise the circuit. It is also the test you carry out when you get a call to somebody with a tripping RCD. It doesn't always give the answer, as it may be due to earth leakage, but it would have saved you a lot of time this time around.
