hi
you might remember seeing my other post about fitting a new feed to the boiler (and yes, i notified building control first!!)
thing is, i have got a split CU, with what looks like a split neutral block. The neutral line of the RCD side is connected to one side only - with all the neutrals of the circuits on the same neutral block.
I fitted the MCB (Type B, 6A), and connected via a connecting box to the 2.5 T&E going to the 3 A fused spur in the airing cupboard where the boiler is. Connected neutral into same block as RCD and other circuits on that side.
All fine when turned power on initially, but when the boiler was turned on, it tripped straight out. Tried a steamer, then a hoover in and the same thing happened.
When i moved tghe neutral to the other neutral block, the RCD stopped tripping but then i had split the circuit and it would not function properly.
Rang and spoke to a sparky and he said to fit it on the non RCD protected side as RCD's can be a pain in the arse when it comes to things like boilers cos of the electronics and pump and fans etc.
Anyway, i moved the MCB to the other side and all is now fine. As the cable goes up into the floorboards and then straight up into the airing cupboard into FCU, then i should be ok with regard to the regs.
Does this sound ok??
cheers
george
cheers
george
