    Dismiss Notice
Really Quick Question about Speedfit Inserts
Discussion in 'Plumbing and Central Heating' started by leevis, 29 Nov 2020.
  1. leevis
    leevis
    2 May 2007
    527
    Thanks Received:
    3
    Country:
    Hi
    I ge that when i am using speed fit 15mm i need to use the STS when going up plastic to plastic.
    I need to join this to a couple of radiators which have a compression olive fitting on the trv end and the shield end, should i be using the plain one (TSM) so i can use the olive on the fitting?
    Or are the STS ones able to be used in both instances? ie don't use the olive
    Confused
  2. Elkato531
    Elkato531
    22 Jul 2009
    1,085
    Thanks Received:
    277
    Sussex
    Country:
    According to John Guest, the manufacturer of Speedfit, a plain insert should be used with compression fittings. You would get away with superseal inserts as long as the pipe is inserted far enough into the fitting so that the olive sits on the pipe beyond the insert. Whichever insert you use, the olive must be in place or there will be nothing holding the pipe in the fitting.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. leevis
    leevis
    2 May 2007
    527
    Thanks Received:
    3
    Country:
    i think i will get some of the plain ones :) many thanks
  5. Madrab
    Madrab
    4 Oct 2012
    8,036
    Thanks Received:
    2,274
    East Renfrewshire
    Country:
    Yes, use standard inserts. The superseals have the rubber o-ring just there the olive can compress the pipe, not advisable.
  6. Sponsored Links
  7. polesapart
    polesapart
    27 May 2011
    1,336
    Thanks Received:
    343
    Country:
    Recommend sliding nut and olive onto pipe before inserting insert!
    • Like Like x 3
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
