Recessed Blanking Plates for sockets
23 Jul 2009
Leicestershire
Our back bedroom has been converted into a Bathroom, with all the electrical sockets being decommissioned by a qualified electrician. He has left the sockets with regular thick white blanking plates on. I'm just wondering if I could get rid of those plates, attach a recessed blanking plate of some description and plaster over it to get rid of the unsightly things! All the sockets are at ground level in the bathroom, so so there's no chance that anyone will want to do any drilling in there.
What are people's thoughts about this? Is it safe? Is there such a thing as a recessed blanking plate? Where would I find one?
Many thanks,
Gareth
If the cables are still live in the wall, then it would be unwise to remove evidence of the blanking plates.
This would remove any indication that the cables exist and could lead to other problems.
Yeah they are still live... I'm starting to think he should really have pulled the cables out rather than just crimp them off if I wanted to get rid of them completely.
No, we got someone in to do the bathroom conversion, and the electrician was a subbie for him. I had no input on that part of the project at all.
as far as I remember, only the bill!
It was about a year ago now, part of a big refurb job on the house, we're only just getting to decorating the bathroom properly now
you will have to find where the cables go to and join them, either under the floor or above the ceiling.
If the room is currently empty, it should be fairly easy to locate the cables under the floor.
If the sockets are part of a ring or in the middle of a radial, you need to locate the two cables exiting the room and find the 2 sockets they are connected to. Those cables are removed and a new length of cable connected between the two sockets, so no need for connections under the floor. (The new cable can go under the floor)
If they are at the end of a radial it is even easier - locate the socket immediately before the cable enters the room and disconnect it there.
Still a blanking plate but marshall tufflex do a white pvc blankplate only about 2mm thick, slightly less obstrusive maybe.
