Recommendation for Bathroom Air Extractor with Humidity Sensor
14 Sep 2005
Milton Keynes
Hi all,
Please can you recommend me a bathroom air extractor with humidity sensor. I'm looking to buy 4 to replace the ones that I currently have (all 10 years old and noisy/failed - I moved into the house 3 years ago). 3 bathrooms with showers/bath and 1 room with just a toilet.
I have looked on www.diy.com and www.amazon.co.uk but find these sites lacking in information and/or the reviews are very mixed.
do they go straight through the wall in a 100mm-ish tubular duct?
this brand seem very good to me. Much quieter than the old designs, and use far less electricity. There are several other makes using modern efficient and quiet motors as well. Usually about 80 cu.m/hr
https://www.tlc-direct.co.uk/Manufacturers/Soler/4_Inch_Fans/index.html
I wouldn't go for the humidstat version though. I'd have one that comes on automatically with the light switch, and runs on for a timed period afterwards.
If you have ducts running in the ceiling or through adjacent rooms, you can use a ducted inline fan, which can be two or three times as powerful, and very quiet. They are larger so are often placed in the loft, sucking through a grille in the ceiling, with a duct running to the eaves or gable wall. The extra power is very suitable if the occupiers have frequent steamy showers. Avoid the cheap little white ones sold in DIY sheds. Look for 180 cu.m per hour or greater.
For example https://www.tlc-direct.co.uk/Products/SLTD160T.html but there are several brands
I think so, but I'll check.
That's what my current ones do. Okay, I'll go for the same function.
Thank you very much for your help :)
The fan is too far from the shower, by the time it’s triggered by moisture the room will be full of moisture.
Should be above the shower in ceiling ideally.
