recommendation plumber in poole to do powerflush
16 Apr 2006
Dorset
can anyone recommend a plumber in Poole? seems system does need a power flush i removed a rather blocked three way valve and the piework downstream looks pity choked, any idea what to pay for a powerflush?
Keith
British Gas charge £400, I paid £350, if you email me I will pass on your e mail address and requirements to someone local to you.
Sorry, I was going to say that I believe it is not allowed to directly advertise services on this forum, hence the reason I didn't leave the address directly.
£300 for up to 10 rads.....£25 extra per extra rad.
thats what i'll be charging when i get my kamco and its what s few of my plumbing mates charge
It said:
FLOW RATE 91lt/min,
Yeah sure. I know where they come from, cos that nonsense comes from there too, and I recognise it.
I have used one, and they're not great, but I haven't used a Kamco, which by the sound of it are also a bit weedy.
The motor's the same size, but whether the impeller parts are the same/as good (Kamco went through a couple of design iterations), I don't know.
Stooge around the forums for Jason Vaughan (Bournemouth)
We have two chris,
One huge one, dont know the flow rate but was man enough to do a 25 rad system to a tee and can do up to 60 according to the blurb :shock:
www.kamco.co.uk
and one smaller one ok for upto 25 odd rads, I will try to find out the flow rate and they dont say what it is on their website
but they lads who are using them day in and day out rave about them, we did try the fernox and sentinel ones but they werent as user friendly as the kamco
i would offer my services but im overloaded with work at present try JC gas in poole jeff will sort you out im sure
That link may not be the best price for that unit!
Its not really the unit thats so important but the skill of the operator and particularly the chemicals used which depend on the problem in the system.
In some areas they use "pink crystals", totally unidentified and the source of four problems I have had to investigate.
