Hi. I need to move my gas meter since the pipe [presumably] passes under the walls of an extension I'm building. It's currently on the side wall of the house, and the only other spot for it really will be on the front wall.
From the existing meter there's 1) a pipe that heads down into the ground, runs under a few metres of concrete floor then pops up again to feed the cooker, and 2) a pipe that runs about 6m up and down internal walls and under floorboards to feed the boiler. Like this, schematically:
Questions about reconnecting the supply:
1) Will 22mm pipe have to be used? It's all 15mm at the moment and I know that's not approved of these days. When altering the gas "network" in the house do I have to update the whole thing to meet current regs, or just not make it any worse, i.e. use 22mm for new parts but leave existing 15mm?
1.5) If I don't have to replace everything with 22mm, can I have the new pipe from the new meter simply find its way back to the old meter's location, reduce to 15mm and join up with the existing pipes that way?
2) Can the pipes be run pretty much anywhere I want them to be put (e.g. on internal walls, under floorboards, through walls, whatever...), meaning the minimum disruption (digging up the floors would be a real pain)? Can they run on the outside face of the house at all, or do they have to go from the meter straight into the building/ground somewhere?
Could I end up with something like this:
N.B. - I know that I won't be doing the work myself, don't worry!
