We have moved into an old house and have decided to install a central heating system. What are the pros and cons of both systems and average lifespan, ie is one far likely to outlive the other on average.
Deduct 2kw (allowance for hotwater) to get the heating requirement.
Add 15% to give the total radiator requirement (This allows the boiler to run in condensing mode more of the time)
How you divide the total rad requrement between rooms is up to you - by room volume is probably the best.
Unless you need large amounts of hot water all at the same time, a combi will be more economical, both to install and to run.
High end modern combis will happily run 2 showers at the same time, as long as you don't require a waterfall. If you want 2 big, powerful showers simultaneously, or more than 2, you will need to look at a system with a large cylinder.
