Hi All,
I am a new member to this website and I hope you can help me fix my current problems - at the moment I have a building site for a living room
We are completely overhauling our living room and we thought it would be nice to purchase a flat screen TV and have it mounted to the wall. The existing TV we had was an old tube type and it was just on a shelf, however the plug sockets and TV arial point are not suitable for our wall mount plans.
Therefore, I have done the following:
How the Wires were before I started any work:
Double socket, metal backbox chased into wall and two cables which are also chased into the wall upto the ceiling.
Arial socket, metal backbox chased into wall and one cable which is also chased into the wall upto the ceiling.
What I have done:
I have located the wires which feed the double socket, by pulling up the floor boards in the bedroom above, and I have cut the wires and fitted two 20A junction boxes. I have fitted one wire into each junction box and fitted two lengths of 2.5mm cable to feed the new power sockets - in essence the junction box is just allowing me to connect the old wires to the new wires.
https://www.dropbox.com/s/pvdqws2t8hbxkw3/20140223_130642.jpg
What I need to know is:
1) Is it OK to wire the cables using the configuration outlined above?
2) For the old cables which are still in the wall and dead (I have tried to remove but they are solid into the wall), is it ok just to plaster straight over the old metal backboxes?
3) Since there is now a combination of old and new power wires, I need to put a warning label on the fusebox for the applicable circuit?
4) The new wires which I have fitted have been fitted into quite a large recess and will be encapsulated in oval conduct, does the conduct need to be secured to the plasterboard? I know it has to be vertical or horizontal and cannot be a mixture of both.
5) Before powering up the new circuit will it require certification? I am assuming I am just adding new sockets to an existing circuit, so I don't believe it does..?
Sorry for the list of questions but I want to ensure I do this right, I have been lots of sources and some are extremely conflicting.
Thank You
Lee
What I have done:
Thank You
Lee
