Remeha 28c problem!
The problem is still on going. We are having to switch the boiler off in between using the hot water. We are going to by-pass the rads when my brother has a spare day, and check all the pipe work for a blockage before I look at a PCB.
The df du values are still both 1, even after I have changed the parameters for propane firing.
I will speak to Remeha Spain later and see if they have an engineer in the area but as one place is 5 hours drive from here and the other 7 it seems doubtful.
Thank-you very much for everything.
I will post again if it gets fixed and let you know the problem.
Otherwise, I think I am looking at a Vailant!!!! Loads of engineers around here and a good 2 year full warranty!!!!
Julie-Anne
What is the value of Parameter 21 - pump speed? The default is 0 (low speed). It might be worth trying it on 1 (high speed).
have you checked that the divertor actuator is working? has it become unplugged?
I had an issue with CH not working and code '8'. It was due to a tap not being 100% closed so the diverter stayed in HW mode. Checked all the taps and CH worked again.
