Hi, this is my second thread about the same boiler on this forum, which I believe says a lot already.
But still looking for some advice.
Roughly 10 years old Remeha combi boiler, we moved in 2 years ago and have so far replaced PRV, pressure gauge, expansion vessel and the last one was a hydraulic block and actuator which was leaking. Total cost for these over time, if I remember correctly, was around £600. And I also had a system powerflush done and a Magnaclean installed (roughly £500) when I had the new PRV installed.
Ok, now I have noticed for a while that the pressure is dropping yet again and upon checking for more leaks, I have found what you can see in the pictures. I think it's the pump itself now?
Boiler still working though, so far.
Now, should I spend more money on fixing this boiler or just bin it and grab a new one?
Which again leads me to my next question, is there a reliable brand that doesn't cost a fortune, but it's built to last for a while, doesn't give you too many headaches and in case something goes wrong, is easy to repair?
I have been recommended Ideal logic 30kw so far (£1700 installed, 10 years warranty) and Worcester Bosch by 2 different installers. Did not get the price for the WB yet, however was wondering what are people's views on these newer, modern combi boilers? I have heard good things about Viessmann too.
Thank you and apologies for the long message.
