Ok guys. I have been thinking of the access with the hidden cistern if the cistern was completely enclosed and something was to go wrong.
I am tiling halfway around wall and I want the box around the cistern/frame to be tiled to.
I have read the top of the box (where the flush plate will be) should be removable with laminated wood or similar. But in case the whole cistern needed to come out I was thinking of fitting a plywood panel that was removable. In the provided images you will see the wall hung toilet in place secured against half of plasterboard. I could either have one whole panel or two halves?
This panel would pop off if you removed the top removable access panel/lid and placed your hand behind the panel to remove it. Of course there would have to be some sort of push fit fasteners which would be secured to the rear of the panel then would mate with some fasteners secured to side batons vertically on each side of frame secured to wall.
If the batons or metal box tube was secured to walls then you could butt the wall tiles on both walls to baton/box tube then fasten the panel then tile on top so tiles are lined up with tiles either side. If required then just the tiled panel can be popped off for access. If you fix tiles onto plasterboad and you have problems behind then you're in trouble.
I need some visual ideas. I have googled this idea and I haven't had much luck. I am wondering if their is somebody reading this who have done this to there downstairs loo? Photos would be great or/and injection of ideas or point me in right direction? Thanks guys
