I have recently purchased a property which I believe the previous owner has believe it or not tiled over the mains internal stop cock.
I am basing this thought on the fact that we cannot see a stop cock anywhere, and when asked neighbours either side of our property and across the road, theirs is accessed via a hatch in the bathroom (our bathroom is completely tiled), this would tie in with the fact the old cold water tank used to sit directly above the bathroom and would have been mains fed.
Obviously I am concerned with what happens if we need to put the water off in a hurry and would like to rectify the problem before there is any issue with needing to put the water off.
I am planning on measuring at the 3 neighbours houses the position of the stop cock / hatch, then basically 'taking a punt' that will be where ours is, as they are all bungalow properties of the same layout.
I then plan to remove 1no tile in this position to see if I can locate the stop cock, the tiles are fairly large (approx 150x200mm) so removing one should give enough room to get hand down the back of the wall to see if indeed the stop cock has been tiled over.
Can anyone suggest a method of removing the tile without causing considerable damage? Scrape out the grout, then try and get the likes of a wallpaper scraper down the back of the tile and pry it off?
I will probably form a hatch as per other properties.
Or does anyone have any other suggestions?
Kind regards,
Callum
Kind regards,
Callum
