Removing recessed spotlights.....
15 Nov 2005
London
So I have got the bulb out and it seems that the, ahem, wire thing it plugs into is not working. (Would they fail after 4/5 years?) So to replace this, it now seems I have to take out the whole recessed light from the ceiling to get at the wires.....
This seems to have happened on half of the lights in the house, is this likely?
Is the spotlight casing held in by some springloaded arms which an be removed easily or would it be model specific?
Yes
No
How do you know this? Telepathy?
Or even sooner.
Or the transformer if its ELV.
Are you out of your depth??
I dont know yet, this is why I am asking questions.
Yes
So model specific or spring loaded arms?
No, the light did not operate with a new bulb so I am assuming that it is the connector. Can you suggest something else apart from sarcasm?
ELV?
If you have several lights out, it suggests a circuit problem, rather than an individual fitting. It may be that some cable has come disconnected some way down the line, or these are all 12v lights (ELV) and the transformer is broken.
I would suggest investing about a tenner in a cheap multimeter, and that will help you track down the fault.
I was not being sarcastic I was trying to help you to see that we need details to diagnose a fault and help you.
If you visit your Doctor and complain of a headache but omit to tell him/her that the carbon monoxide detector has been going off for the last week, you will not find a satisfactory solution to your problem
What made me think it was more localised is that there doesnt seem (to the untrained eye) any pattern to the lights which arent working (just moved into this house). On average 1 light per room, the most is 2.
Also a couple of the leads which connect to the bulb are broken/damagaed, which led me to believe that the rest could be like it.
The lights are 5V located in the ceiling.
....if this makes it easier!
Thanks for the advice/responses
5v :shock:
sorry that does not sound right at all.
why not look on say screffix for one similar or post a picture of your light
er..more like 12V 50W ones....sorry
So would you still think it could be a transformer problem ir there is no distinct pattern to the failures (like one floor out ot something)?
ill take a look for a piccy of the lights
For those that were gripped by this saga, it was the lamp holders on the majority of the lights which were sourced from a good co. on the internet in the end. Homebase/B&Q seem to overlook these.
