    Dismiss Notice
Replace Danfoss oilpump with Suntec
Discussion in 'Plumbing and Central Heating' started by FiveKnuckleShuffle, 22 Sep 2019.
  1. FiveKnuckleShuffle
    FiveKnuckleShuffle
    21 Feb 2007
    40
    Thanks Received:
    Tyne and Wear
    Country:
    Hi all.
    Does anyone know the best way to select the right Suntec pump in order to replace a Danfoss BFP 41 L3 No. 071N1206 please?
    It's on a Worcester Danesmoor 12/14
  2. Sponsored Links
  3. Hairymelon
    Hairymelon
    30 Sep 2017
    310
    Thanks Received:
    73
    Norfolk
    Country:
    What’s the advantage?
  4. FiveKnuckleShuffle
    FiveKnuckleShuffle
    21 Feb 2007
    40
    Thanks Received:
    Tyne and Wear
    Country:
    Well it will function for starters lol
    The Danfoss one is kaput and I've read the Suntec ones are better or more reliable so opportunity is there to swap.
  5. Hairymelon
    Hairymelon
    30 Sep 2017
    310
    Thanks Received:
    73
    Norfolk
    Country:
    Ask Worcester
  6. FiveKnuckleShuffle
    FiveKnuckleShuffle
    21 Feb 2007
    40
    Thanks Received:
    Tyne and Wear
    Country:
    I've posted here in case anyone knows.
  7. Hairymelon
    Hairymelon
    30 Sep 2017
    310
    Thanks Received:
    73
    Norfolk
    Country:
    i know when it left the factory it had a danfoss
  8. FiveKnuckleShuffle
    FiveKnuckleShuffle
    21 Feb 2007
    40
    Thanks Received:
    Tyne and Wear
    Country:
    Well since your doing your best to be unhelpful hopefully someone else might be able to help.
  9. Hairymelon
    Hairymelon
    30 Sep 2017
    310
    Thanks Received:
    73
    Norfolk
    Country:
    You know best obviously. If you had any common sense you would put on the manufactures specified components and have several years trouble free operation. Unless your oil supply is contaminated or needs a tiger loop. Consult an oftec engineer and stop dreaming
  10. Sponsored Links
  11. FiveKnuckleShuffle
    FiveKnuckleShuffle
    21 Feb 2007
    40
    Thanks Received:
    Tyne and Wear
    Country:
    Yep thanks again for your wonderful input.
  12. Hairymelon
    Hairymelon
    30 Sep 2017
    310
    Thanks Received:
    73
    Norfolk
    Country:
    Ok Ask Worcester which one of us is the bellend
  13. muggles
    muggles
    28 Oct 2005
    12,753
    Thanks Received:
    2,828
    Daventry
    Country:
    I agree with Karatekid, I'd stick with Danfoss
  14. oilboffin
    oilboffin
    26 Apr 2011
    1,665
    Thanks Received:
    247
    isle of Lewis
    Country:
    Danfoss are a supierior pump to suntec personally I wouldn't use a suntec danfoss are very good pumps it could be you need exocet in your oil.Bob
  15. oilhead
    oilhead
    29 Nov 2009
    2,052
    Thanks Received:
    489
    Shropshire
    Country:
    I can' think which Suntec would replace a Danfoss BFP 41 L3, as this has an offset solenoid. At a pinch you can replace with a BFP21 L£, but you have to re-form the nozzle pipe. The Suntec pump is physically bigger, and on a B9 burner, which is what you have, you will have a bad time with the nozzle pipe.
    I personally don't think there is any reliability issue with Danfoss, especially now they have uprated the coil.
  16. FiveKnuckleShuffle
    FiveKnuckleShuffle
    21 Feb 2007
    40
    Thanks Received:
    Tyne and Wear
    Country:
    Thanks for the comments which were helpful.
    I went with the Danfoss in the end.
    Only two things left to do are try the exocet in the oil Bob mentions - Is this easy to do?
    Lastly check and if necessary set the pressure with a gauge.
  17. Burnerman
    Burnerman
    7 Feb 2008
    22,573
    Thanks Received:
    4,398
    Northumberland
    Country:
    Exocet is an oil additive which is claimed to promote cleaner burning and protection to the pump / tank and whatever.....by all means use it! I don't use it personally as I regularly service my burner but I have used it with success on the old Nu Way ZL2 series that weren't too efficient and had no purge facility (Thats dating me :eek:)
    If I can give you a tip on the new pump installation - don't overtighten the allen screws that hold the pump in place, I've found the thing to be happier if allowed to float a fraction.
    (just my opinion).
    John :)
    • Like Like x 1
Loading...
Share This Page
