Hi - I have an external garage constructed out of single skin concrete blocks and outside rendering. There is a window on a side wall that I want to replace with a brand new upvc door. The window has a concrete lintel on top. Since the door I intend to fit is narrower and will fit within the space of the window, am I right in thinking that cutting the wall down to fit the door and bricking up the left over window whole is all non-structural work and therefore relatively safe to do - since I am not touching the lintel OR the wall on which the lintel is supported?
Also, I am not sure what the "lip" is at the bottom of the wall of the garage, which I will have to cut if fitting the door. Anything structural that I need to be aware of?
Finally, is it enough cutting the blockwork and fitting the doorframe that comes with the door or must I fit wooden pillars to each side of the door opening? (Door will be like this one: http://www.diy.com/departments/whit...ack-door-frame-rh-h2055mm-w840mm/26994_BQ.prd) Thank you!
