Hi all its me again.
Been busy on some other matter and only just connected outside bell as per
Sparky instructions.
Carried out test as per manual and both internal and external alarms working.
Also carried out walk test as per manual and detectors are registering ok on the panel.
Reconnected magnetic contact to front door and to control panel.
Great so far, only problem is that whatever I do I cant set the programme
When I try it beeps twice, and when I leave exit route it beeps 4 times.
This continues even if I cause detectors to flash and none of the alarms go off.
I have attached some pics of the wiring to the panel in the hope that somebody can spot my mistake.
