    Dismiss Notice
Replacement fluorescent tubes and starters
Discussion in 'Electrics UK' started by Antony D'Emanuele, 8 Apr 2021.
  1. Antony D'Emanuele
    Antony D'Emanuele
    8 Apr 2021
    Thanks Received:
    Country:
    My mum has 2 fluorescent light fittings as follows:
    1) Two tube unit with the following on each of the 5ft tubes: Osram L 58 W/23
    2) Single tube unit with the following on the 5ft tube F58W/840
    What warm light replacement tubes and starters should I buy? Also are there LED alternatives and if so what tubes and starters?
  2. Sponsored Links
  3. AndyPRK
    AndyPRK
    4 Jan 2009
    5,471
    Thanks Received:
    526
    Herefordshire
    Country:
    Energizer sell led tubes (eg ebay). And come with “starter”
  4. AndyPRK
    AndyPRK
    4 Jan 2009
    5,471
    Thanks Received:
    526
    Herefordshire
    Country:
  5. 333rocky333
    333rocky333
    12 Jan 2008
    8,146
    Thanks Received:
    851
    Essex
    Country:
    Osram 58W 23 was a white tube, equivalent now would be a 58W 835 Tube
    58W 840 is a Cool white tube and still exists as a 58W 840 Tube
    So both were different colours anyway.
    If you want light similar colour to a Light Bulb then opt for colour 835 White Tube
    Are you sure the fittings have starters, if so.
    All the above tubes use the same FSU starter which is for 58 watt
  6. ericmark
    ericmark
    27 Jan 2008
    17,557
    Thanks Received:
    1,628
    Llanfair Caereinion, Nr Welshpool
    Country:
    Note a LED starter is not really a starter as such, it is more like a fuse, many 22 watt LED tubes will work without any rewiring just change the starter for a fuse.
  7. Sponsored Links
  8. winston1
    winston1
    11 Jan 2010
    6,488
    Thanks Received:
    494
    London
    Country:
    The so called LED alternatives use approx half the power and are half as bright. I replaced a 4 foot 36 watt tube with LED and the first comment I got from the other half was “why do dim?” So it went back and I got a standard fluorescent.
    Generally no need to replace the starter when getting a new tube but if you do get the electronic type.
    • Like Like x 1
  9. AndyPRK
    AndyPRK
    4 Jan 2009
    5,471
    Thanks Received:
    526
    Herefordshire
    Country:
    I guess it depends what brand you buy.
    Energizer ones are bright enough. Usually brighter
  10. winston1
    winston1
    11 Jan 2010
    6,488
    Thanks Received:
    494
    London
    Country:
    The web quotes 1800 lumens for a 4 foot Energiser tube and around 3500 for a 4 foot fluorescent. Yet many quotes on the web saying LEDs are brighter. I think people must be deluding themselves. Myself, and my other half, definitely find LEDs dimmer as the outputs suggest we should.
  11. AndyPRK
    AndyPRK
    4 Jan 2009
    5,471
    Thanks Received:
    526
    Herefordshire
    Country:
    I've only used the 6ft versions.
    I like all the energizer led products, except G9.
    I think energizer have gone out their way to ensure the output is brigher than one would expect to avoid disapointment and poor customer feedback
Loading...
Share This Page
