replacement neon (or LED) indicators
Have you examined it? Is the neon in the right place.
I think you will find plenty of switches of that design with led indicator in Europe.
Yes, examined and moved the neon to directly behind the clear cut out, and now held by epoxy and a cable tie.
Where it was originally fitted, on the side, in the vertical middle, about 18mm offset from the ‘window’ it was even worse !
It has taken two weeks of searching to find these No LED ones to be found.. this neon one was like finding needle in a haystack
Even down to the plastic moulding the original one has, it looks identical. Which is the issue, they are just too damn dim.
If you are used to the standard UK ones by MK, that you see on cooker or hot water boiler tanks, then these Legrand ones are like an Everyready D cell 1970’s bicycle lamp compared to a modern car LED Headlamp. TBH they are a joke.
Good grief, this thread from 2017. I'd forgotten about it.
