Replacing a PIR
17 Jun 2010
Northumberland
I've bought a new PIR to replace a 10 year old one, however the terminal names are different. The old PIR was:
C BLUE WIRE
NC RED WIRE
+ YELLOW WIRE
- BLACK WIRE
& 2 TAMPER WHITE AND GREEN WIRES
However the new PIR is:
2 RELAY N.C
2 TAMPER N.C
GND
+12V
How should the new block be wired?
Thanks in advance
blue and red wire alarm NC
white and green tamper NC
0v - black wire
12v + yellow wire
the NC tamper and NC alarm are not polarity dependant, in other words you can wire them there is no volts to worry about.
make sure that you connect tamper connection to tamper connection and alarm connection to alarm connection.
other wise whaen you have finished you will walk in front of it and the system will go into tamper !!!!
as long as you make sure that you dont short the + amd - you wont pop a fuse in the panel
hope this helps
John
